Author Topic: Correct alternator/fan belt size?  (Read 2400 times)
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« on: March 27, 2018, 14:11:51 »
I will be changing my belts soon and that pelican parts and autohauzaz only sell 10mmx900mm replacement belts.
I currently have a 10mm x 925mm belt. Searching the forum yielded this post which also suggests that 10x925 is correct for an early 68/69 280sl.
https://www.sl113.org/forums/index.php?topic=3713.0
Will a 10mm x 900mm work?  What should be the correct size?
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
