Author Topic: Seat frame colour query  (Read 3156 times)
swood1
« on: March 28, 2018, 15:35:32 »
Hi forum,
I stripped one of my seats and noticed the frame itself could do with some cleaning and painting.  It has a green/grey finish on it.  Can anyone direct me to a similar coloured paint for the frame please?  I assume this colour/paint is basically the undercoat and finishing coat in one.
Regards
Steven
Re: Seat frame colour query
« Reply #1 on: March 28, 2018, 21:27:30 »
Yes, Steven ...,
Your observation is absolutely correct.
A greenish-gray paint that is most likely more of a primer than a finish.
Does do its job over the life expectation decently ::)
but not perfect..;
on poor cars rust of the seat frames occurs. :P
When I redid my seats on my car I primed them with 2 K and painted (sprayed) the seat frames with a colo(u)r code pretty close to what it was originally.
swood1
« Reply #2 on: March 28, 2018, 21:42:38 »
Yes after such a long time I can only see some small patches of surface rust which is encouraging.  I shall remove this, teat it and look for something similar in colour.  I guess once they are rebuilt there will be no exposed areas of concern anyway.
Steve
« Reply #3 on: March 29, 2018, 13:10:07 »
Ditzler DP40 is my primer of choice to match the grey/green primer of our cars.  Hopefully, it is available over there.  The center of the body is DP40
swood1
« Reply #4 on: April 12, 2018, 07:46:02 »
Hi Shvegel,
Sorry, what do you mean by the center of the body?  Do you mean the insides of the box sections?
Regards
Steven
« Reply #5 on: April 12, 2018, 12:55:34 »
In the above picture where there isn't the white underseal.  The bottom of the driveshaft tunnel.
swood1
« Reply #6 on: April 16, 2018, 06:39:34 »
I may have found a supplier in the UK for this paint and as it's used as the undercoat anyway I may as well get some.
Looks like PPG Industries UK Ltd supply this paint.  I shall contact them.
Thanks for your help with this.
Regards
Steven
