Author Topic: Proper Hose Clamps  (Read 4960 times)
Tom in seattle
  • USA, WA, Shoreline
Proper Hose Clamps
« on: April 05, 2018, 01:00:01 »
My car has a collection of worm drive clamps with the occasional "as delivered clamp".  I would like to change them out to the original style but cannot locate a local source.  Can you recommend a source (affordable preferred) for the original overlapping band with 2 tabs cinched with a nut and bolt?
Tom Averill
1967 250 SL Auto Euro Spec
Re: Proper Hose Clamps
« Reply #1 on: April 05, 2018, 01:49:38 »
Take a look here: http://www.authenticclassics.com/NOS-Original-Screw-type-Hose-Clamp-13mm-size-p/auth-004314.htm
He has many of the required Norma clamp sizes.
« Reply #2 on: April 05, 2018, 08:38:39 »
 Tom,
Clamp styles went through a couple evolutions.  What year is your car?
The 280’s originally had Gemi clamps but they are no longer available.  The Norma clamps are the best substitute.  Essentially the same clamp but with a slotted screw as opposed to the phillips pan head on the original Gemi.
« Reply #3 on: April 05, 2018, 15:55:30 »
It is very easy to change the screw type. I just ordered a bag of the phillips head style screw from McMaster-Carr (US supply house for all kinds of small bits and pieces).
The Gemi clamp also has a different type clamp set-up. I did go back and clean it up to see if I could raise the information on the clamp itself. I was able to read it, but not get a readable photo. It is stamped "Gemi" and "18"
See photo attached.
« Last Edit: April 05, 2018, 18:39:19 by Jonny B »
ejboyd5
  • Southold, NY
« Reply #4 on: April 06, 2018, 12:37:11 »
https://www.sl113.org/wiki/Engine/HosesClamps
If I remember correctly, Peter Lesler at one time offered packages of correct hose clamps for the Pagoda cars.
« Reply #5 on: April 06, 2018, 15:41:07 »
Pete Lesler took ill a couple of weeks ago, and is recovering. So, if anyone contacts him don't expect an answer for some time.
« Reply #6 on: April 07, 2018, 09:38:33 »
Gemi and Norma are now owned by the same company.  Maybe someday they will make a new die and stamp out some Gemi’s again.  Such a small production run it probably doesn’t make sense but it would be nice if they did.
« Reply #7 on: April 07, 2018, 10:51:45 »
I talked to Norma directly. I thought I would buy some clamps we find on eBay or in Authentic Classic directly from them. No problem, I would just have to order 100pcs per size minimum and the price was roughly EUR 1.5 per pc.
By the way: personally I found the Norma clamps a nightmare to install. You really need to watch the direction the screw is facing and you really need to get the diameter right as the span of dimensions  for these clamps is minimum. I thought of putting in the philips screws - but then it becomes neither Norma nor Gemi...
« Last Edit: April 07, 2018, 11:15:28 by Pawel66 »
« Reply #8 on: April 07, 2018, 14:13:13 »
I like to use the phillips screw type as they are a bunch easier to tighten/loosen, for me anyway.
« Reply #9 on: April 07, 2018, 14:50:36 »
Very true! :o
« Reply #10 on: April 08, 2018, 08:26:09 »
I ordered screws on Amazon the other day.  If I recall correctly the judging standard is original or whatevr Mercedes supplies.  That being said I have heard another standard is as long as the clamps match and are not American worm clamps.  I figure Normas with phillips still match and look closer to Gemis.
« Reply #11 on: April 08, 2018, 19:01:13 »
In trying to find the correct screw presents a challenge. The screw size appears to be 4mm-.7 x 20mm for all of the hose clamp sizes I have. It should be a "cheese head" and with a smaller diameter head than a standard pan head screw. That is the problem. The most common cheese head screw is a slotted head, not a Phillips drive. The closest I could find is:
https://www.belmetric.com/4mm-c-10_74_1343_1349_1354/mspsh4x20clz-small-head-jis-zinc-p-8205.html At least the head diameter and drive is correct. For the ones who bought these, what did you find?
« Reply #12 on: April 08, 2018, 23:20:34 »
The screws I have (I bought a bag of 100) are listed (on the bag) as M4X20 (BN 40058) 4009027 in stainless.I have attached a snap of the screws I purchased.
« Reply #13 on: April 26, 2018, 10:06:28 »
Here are the screws I bought.  They look good.  I will snap a pic of one in the clamp tomorrow.
https://www.amazon.com/gp/product/B009TE4SLK/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
« Reply #14 on: April 26, 2018, 18:01:08 »
Norma with the Amazon screws.
