Author Topic: wipers are stuck  (Read 4192 times)
free2keun
  • Belgium, Flanders, Kortrijk
wipers are stuck
« on: April 17, 2018, 17:22:37 »
Hello Pagoda friends,
Can you help me with this problem.  the wiper mechanism is stuck.  The electric wiper motor works well, slow and fast.  But the rod , inside the dash, is stuck.  I put some WD-40 on it, but after 3 days spraying, it is still stuck.  I put away the glove box to get better to the rod, but this won't move.  The right channel is loss, but the right, the channel behind the instrumental part, is stuck.  How can I get it work without open the hole dash ?
dpreston Virginia
  • USA, VA, Salem
Re: wipers are stuck
« Reply #1 on: April 17, 2018, 17:32:48 »
Go to the bottom of this link and see what I did to lube the posts. Maybe too late. I hear its a huge job to get the mechanism out.
Also I have seen where you could buy a attachment to the wiper post to force grease into the mechanism.
Good luck
https://www.sl113.org/forums/index.php?topic=27222.msg195508#msg195508
190SL 1960 Sold
280SL 1969
280SE 1969 cabriolet
Vette 67
Porsche 912 67
specracer
  • USA, MA, Duxbury
« Reply #2 on: April 18, 2018, 00:11:29 »
Here is the grease fitting adapter, but I would doubt it would be the solution.
http://www.authenticclassics.com/Greasing-Tool-Windshield-Wiper-Spindle-280sl-p/auth-008822.htm
mbzse
« Reply #3 on: April 18, 2018, 09:02:27 »
Quote from: free2keun
..../... the wiper mechanism is stuck.../... How can I get it work without open the hole dash ?
You probably need to disassemble the dash... There was a short artice about this issue in Pagoda Notes 12No1.
Also, a video has kindly been made available see at 5min40sec here; it has some in-depth information:
https://www.youtube.com/watch?v=RsludSaq4E4&feature=youtu.be
« Last Edit: April 19, 2018, 09:01:11 by mbzse »
/Hans S
doitwright
  • USA, IL, Willowbrook
« Reply #4 on: April 18, 2018, 13:57:06 »
Unfortunately, the best long term solution is removal and disassembly. Removing the linkage will require removal of your heat/vent controls, instruments, radio and glove box. This would be a good time to check your heater core, rubber drain tubes and lubricate the heat/vent control cables. When I strarted the reassembly of my restoration, the wiper mechanism was the 1st part I installed. I am not implying that you need to take your entire car apart.  ;)
Frank Koronkiewicz
Willowbrook, Illinois
free2keun
« Reply #5 on: April 27, 2018, 16:50:16 »
Dear friends, the wipers work well now. Thanks to DPreston, the idea of the tubes did it work will !!! :)
specracer
  • USA, MA, Duxbury
« Reply #6 on: April 27, 2018, 22:54:59 »
Great news!
« Reply #7 on: April 28, 2018, 00:50:04 »
...grease fitting adapter...
So now to follow up on your success, you should acquire the grease fitting adaptor that specracer mentioned and properly lubricate the spindles to help prevent future binding.
dpreston Virginia
  • USA, VA, Salem
« Reply #8 on: April 30, 2018, 12:11:58 »
Glad the oil tubes fixed your problem.
What a mess to have to take it all apart.
If you lubed with oil once a year you should be good to go.
« Last Edit: April 30, 2018, 12:59:35 by DPreston »
190SL 1960 Sold
280SL 1969
Vette 67
Porsche 912 67
