Author Topic: fuel pump canister 230 sl  (Read 1872 times)
rjgricius1
  • USA, MI, Mount Clemens
« on: April 18, 2018, 13:56:42 »
Looking for the three prong bracket that holds the canister into place on the frame. See attached photo.
230 sl 1967 automatic
wht/blue  in the middle of comple restoration
Re: fuel pump canister 230 sl
« Reply #1 on: April 18, 2018, 14:39:34 »
I was looking for mine (late), did not find it, so I bought this:
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/47-fuel-tank
which is what you are looking for (early), I suppose.
I had to modify it to fit the late protective cylinder (late 280SL). But for you it should work. It's just that it is far away...
I am sure aftermarket ones are around.
scovor
« Reply #2 on: April 18, 2018, 14:45:11 »
I happened to see this in an earlier post while looking to solve a related issue. Hope it's of use.
https://www.pelicanparts.com/More_Info/1084700281.htm?pn=108-470-02-81-MBZ
It was on this page.
Best wishes,
Scott
UJJ
  • USA, CA, Grass Valley
« Reply #3 on: April 18, 2018, 15:15:22 »
Hi have this bracket and the old (long) style fuel pump.
I replaced it with the new (short) pump not because the old one did not work properly, but because I did not like the noise.
The new one is much quieter.
I squirted some oil in the ports of the pump and closed them before storage.
I sell the parts.
Bracket $20
Fuel pump $100
Shipping not included.
Urban
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
jorge espinoza
  • USA, NY, Nyc
  • 1969-280SL ,1966 -230SL
« Reply #4 on: April 18, 2018, 21:26:26 »
If you get no response I'll by the lot , or just the fuel pump .
