Author Topic: driveshaft bearing mounting order??  (Read 1837 times)
erickmarciano
  • Canada, Quebec, montreal
« on: April 19, 2018, 14:10:54 »
Hi guys
been chasing a noise after I assembled my driveshaft bearing for a few years.
just noticed while doing maintenance that the ring #8 spins freely it is not held in place .is this normal?
thanks
Erick
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: driveshaft bearing mounting order??
« Reply #1 on: April 19, 2018, 15:36:04 »
If I remember my struggle correctly and if I read the drawing correctly (with the small magnifying picture) the No. 11 is a circlip that holds No. 8.
six speed classic Gearbox
« Reply #2 on: April 19, 2018, 16:35:38 »
# 8 it is a dust cap, which is held with a Segerring, should not be loose, remedy, remove the rear shaft and remove the bearing and dust ring, measure and possibly put a spacer in between
Only tighten the clamping nut of the front propshaft by hand
Maybe you are also interested in a better gearbox
I have a six speed classic gearbox offering speeds up to 2000 rpm at 60 mls
best regrads
