Thanks Tyler - any idea how to access the switches? I have the fuel shutoff solenoid disconnected with a voltmeter connected to the wire that was on the solenoid. Starting car cold, no voltage to solenoid no matter where the clutch or accelerator pedal are. As car warms, 12v is present at the solenoid wire. Pressing either the clutch or the gas pedal cuts off the 12v to solenoid, which tells me the car "thinks" it is in 3rd or 4th and decelerating. One of the switches is most likely stuck, or as you say, the wires are shorted. Can the switches be accessed through the opening in the floor or can you reach them from underneath ? Hopefully without dropping the transmission!
Edit: so after looking at the 3rd & 4th gear switches from the engine bay and from under the car, the 4th? (the one towards the front of the car) is stuck "in". I'm not sure this can be changed and adjusted without lowering the transmission? I'll drive it for a while without the fuel shutoff solenoid attached until I have another reason to lower the transmission. The access plate in the floor also might be an option.
Thanks for your help.
