Author Topic: Pinion Bolt Nut Removal  (Read 1628 times)
CJHenderson
  • USA, AR, Benton
« on: May 08, 2018, 18:06:57 »
Which way does the pinion shaft nut come off. Can't tell because the end of the shaft is worn pretty badly.
1950 MG-TD
Re: Pinion Bolt Nut Removal
« Reply #1 on: May 10, 2018, 05:55:00 »
As normal, counter clockwise. Be sure to straighten the lock ring.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: May 14, 2018, 15:16:36 »
Thanks had to use and impact wrench to finally break it loose
1950 MG-TD
