Author Topic: Ignition timing for 250SL  (Read 4143 times)
Tom in seattle
  • USA, WA, Shoreline
« on: May 10, 2018, 00:15:12 »
I have a European 1967 250SL.  It has a 051 Bosch distributor.  The tech manual indicates this is a proper distributor but possibly a 009 distributor may have been substituted by recall later.  The 051 may have a retard mechanism built in, I'm not sure.  I'm hoping someone can tell me how to time this distributor which is using a Pertronix trigger instead of mechanical points.  How many degrees before or after TDC?  With vacuum tube attached or without vacuum?  It seems that the 230s and later 280s may be timed differently due to the distributor used and with or without the retard feature.
Love this site.
Tom Averill
1967 250 SL Auto Euro Spec
Re: Ignition timing for 250SL
« Reply #1 on: May 10, 2018, 02:56:16 »
The 051 distributer is timed with vacuum line attached. It makes no difference having Pertronix or regular points.
The spec is to set the timing to 30 degrees BTDC @ 3000 rpm. However these engines do much better when set to 35-38 degrees BTDC @3000 using premium fuel.
Dont worry about setting timing at idle. Just let it fall where it may.
Tom in seattle
« Reply #2 on: May 10, 2018, 21:51:55 »
Tyler S.  Thank you very much.
Tom Averill
« Reply #3 on: May 10, 2018, 22:33:11 »
I like 38 degrees BTDC @ 3,000 RPM. Most engines run just right at that setting. If your distributor is set up correctly, you will get 8 degrees BTDC at idle.
