Author Topic: Removing Tappered Pin from Right Axel  (Read 3041 times)
CJHenderson
  • USA, AR, Benton
« on: May 14, 2018, 18:36:25 »
Do I need to remove this pin from the flex axel in order to get in and change the oil seal. According to the manual it's a tapper pin that is drawn tight with a nut and washer, if that is the case then the nut and treaded end of pin is long gone.
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
mbzse
Re: Removing Tappered Pin from Right Axel
« Reply #1 on: May 14, 2018, 20:21:18 »
Quote from: CJHenderson
.../...it's a tapper pin that is drawn tight with a nut and washer.../...
You will find some info about it in these Forum postings
https://www.sl113.org/forums/index.php?topic=23899.25
/Hans S
CJHenderson
  • USA, AR, Benton
« Reply #2 on: May 14, 2018, 23:57:24 »
Thanks for the link. I have been hitting it with a large hammer but guess I need a bigger hammer. It was evident that someone had worked on the tapper bolt since the threaded end had been sheared off. I would just hate to remove the pinion just to get the right axel out.
1950 MG-TD
« Reply #3 on: May 15, 2018, 01:04:45 »
I'm a bit unclear about what you're trying to do. The pin should drive out from the end that had the nut on it and the shaft has a milled area for the pin to slide through which also locates the shaft. If someone tried to draw it through without having the shaft centered for the pin to slide through it could be why it's stuck and why they broke the pin off.
1988 560SEC
mbzse
« Reply #4 on: May 15, 2018, 10:47:50 »
.../... It is a tapper pin that is drawn tight with a nut and washer.../...
After looking at your picture with arrow I took the liberty to modify it to point to the tapered pin.
« Last Edit: May 29, 2018, 19:53:15 by mbzse »
/Hans S
« Reply #5 on: May 15, 2018, 15:15:27 »
That makes a lot more sense Hans. I guess what was pointed to prior were blind holes for casting purposes/alignment purposes?
mbzse
« Reply #6 on: May 15, 2018, 17:20:59 »
Quote from: wwheeler
.../...what was pointed to prior were blind holes for casting purposes/alignment purposes?
Precisely. Blind holes used for fixating the item when seats for bearings etc. were machined
/Hans S
« Reply #7 on: May 15, 2018, 22:08:31 »
Move the swing axel up then drive the pin out with a drift. I leave a nut threaded to the end and flush on the pin so the threads have less a chance of being damaged.
CJHenderson
  • USA, AR, Benton
« Reply #8 on: May 15, 2018, 22:21:47 »
Thank you for showing where it is located. My manual led me to believe that the hole that I was looking at was the spot. You have saved me a lot of wasted time.
1950 MG-TD
« Reply #9 on: May 20, 2018, 23:03:47 »
What Joe says about protecting the threads is important.  The tapere pin sells for over $100 these days.
mbzse
« Reply #10 on: May 21, 2018, 10:01:29 »
Quote from: Shvegel
.../... The tapere pin sells for over $100
Really!? Wow.
 Well, I see SLS has them for 12,50 Euros...
« Last Edit: May 29, 2018, 19:54:25 by mbzse »
/Hans S
