Author Topic: Another full rebuild thread  (Read 9287 times)
Re: Another full rebuild thread
« Reply #25 on: May 22, 2020, 13:16:14 »
« Reply #26 on: May 22, 2020, 15:36:08 »
What's the MB part number for the feeler gauge you used for checking the sump/subframe gap? ;)
Which mounts have gone? Engine or subframe (which I assume is weight bearing on the ramp)
« Reply #27 on: May 22, 2020, 15:54:16 »
Only engine mounts are relevant for this gap since the engine sits on the sub frame.
Failed sub frame mounts will be seen when car is elevated like this as the sub frame hangs from the sub frame mounts and this tests them to their limit.
You will see them either completely separated or showing lots of deep cracks.
I checked my records and they're two weeks inside warranty!
RobSirg
« Reply #28 on: June 10, 2020, 04:32:46 »
Are they Michelin Whitewalls? Are they still available?
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #29 on: June 10, 2020, 13:13:30 »
Yes, by special order and lots of money.....
RobSirg
« Reply #30 on: June 10, 2020, 23:58:44 »
Interesting.
Can you please tell me the size - 185? 195? What ratio - 70? 75?
What are we talking about per tyre (if you don't mind my asking?)
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #31 on: June 11, 2020, 08:32:46 »
the correct tyre size; 185/14
I could check but from memory over £200 each plus VAT.
RobSirg
« Reply #32 on: June 11, 2020, 10:55:41 »
Thanks Stick👍
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #33 on: June 11, 2020, 12:19:51 »
It COULD be argued that's not bad as Longstone are selling the MXV-P (with the rub strip) at £214 (inc VAT)
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
« Reply #34 on: June 11, 2020, 17:25:14 »
There's always the Coker Company Firestone Phoenix tire which has a similar look to the originals ~$296/tire for whitewalls
JB
JB; 1965 German market SL, Rot Met 571, Summary Code 213 Interior
« Reply #35 on: June 11, 2020, 18:26:13 »
I always thought that 185 is a bit small but maybe the original tires had a different aspect ratio than today. For regular tires, I think 195 works better.
« Reply #36 on: September 01, 2021, 15:54:08 »
It seems I was remiss in posting the final pictures!
johnk
  • USA, OH, Avon
« Reply #37 on: September 01, 2021, 17:13:05 »
Beautiful work Stick!
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
