Author Topic: Help! Can't Reweld Hood Mount Brackets  (Read 2924 times)
hlblanton
« on: May 29, 2018, 18:21:00 »
My '71 has been undergoing a long, expensive restoration here in Southern California. All seemed buttoned up (wiring in particular was a mess) but we've run into one final problem. The brackets that attach to the aluminium hood came undone and my shop (or rather, the body shop they sent it to) has been unable to do an adequate re weld. I understand that aluminium (not to mention almost 50 year old) is hard to work with. But has anyone had this problem or have any ideas? Are there aluminum specialists (car or otherwise( that we could send the hood and brackets to? I figure we'll need to do a repaint on the hood after this but in that regard I'm kind lf lucky having the basic white which I've been able to match at my paint shop in the past.  Any help, thoughts or pity would be appreciated!
HLB
49er
  • USA, CA, El Dorado Hills
Re: Help! Can't Reweld Hood Mount Brackets
« Reply #1 on: May 29, 2018, 18:37:26 »
What brackets are you referring to? The front hinge brackets are bolted on.
John
1969 280SL 003820
4 speed manual, PS. 77K+miles
7K+ miles since awoken from her 20+ yr "nap" in 2010
mbzse
« Reply #2 on: May 29, 2018, 19:00:17 »
Quote from: hlblanton
.../...The brackets that attach to the aluminium hood came undone.../... has anyone had this problem or have any ideas?.../...
The Search function is your friend.
For instance this: https://www.sl113.org/forums/index.php?topic=16945.msg117139#msg117139
/Hans S
