Author Topic: Missing and smoking  (Read 2032 times)
Richard
Missing and smoking
« on: June 01, 2018, 08:59:56 »
I’m new to the group so thanks for allowing me to join. Can anyone help please
My 1966 230 Auto Pagoda has suffered an engine fault where it started expelling dark smoke from the exhausts, lost power and generally sounded rough. I turned it off as soon as I could. It was smelling of fuel over the last few months but I put that down to its age.
Can anyone provide any ideas to what could be wrong please?
Also do you have any contacts in the UK for parts and part brochures?
Many thanks in advance.
Re: Missing and smoking
« Reply #1 on: June 01, 2018, 15:27:17 »
Hello Richard,
 First check all your fluids to see if you have any unusual consumption. Sounds like you have a sudden rich running situation. It might be something stuck on the fuel injection. Possibly the cold starting valve on the intake manifold could be stuck open? Many other possibilities, but very black smoke is most often excessive fuel. White smoke could be coolant, or auto transmission fluid. Bluish smoke could be oil.  Remove your spark plugs and look at them for clues.
« Reply #2 on: June 01, 2018, 16:43:35 »
 My first check would be oil level in the MFI pump.
« Reply #3 on: June 01, 2018, 17:14:07 »
This may not apply but the last time I was involved in a '' missing and smoking '' situation it was in grade 12 and I was sent home from school for a few days. ;)
Richard
« Reply #4 on: June 01, 2018, 19:02:26 »
Thanks for your comments, I appreciate it.
Richard
« Reply #5 on: June 04, 2018, 19:08:02 »
That’s great, many thanks sir.
Tom in seattle
  • USA, WA, Shoreline
« Reply #6 on: June 12, 2018, 06:10:38 »
Pull spark plugs and see if one or all are fouled with oil or unburned fuel.
Tom Averill
1967 250 SL Auto Euro Spec
