Author Topic: 280SL A/C FRIGIKING  (Read 3489 times)
Thierry du Laos
280SL A/C FRIGIKING
« on: June 05, 2018, 07:39:05 »
Back on the car to finalize some items I left pending. I don't remember how was connected the AC Frigiking ?
I have the wires coming from the unit but can't remember at the engine bay...!
There is a little fuse holder for 2 fuses. I think one for the AC, and maybe the second for an electrical antena?
I think the 12V comes in the car loom. Who can help me to remember...?
Thierry from Laos
450sl
Re: 280SL A/C FRIGIKING
« Reply #1 on: June 05, 2018, 09:05:07 »
There are  2  +12v wires , attached to the frigiking.  The thicker wire is going to the pumpclutch , the other wire is the +12v for the unit.
Thierry du Laos
« Reply #2 on: June 05, 2018, 13:51:11 »
Hi 450SL,
Do you mean the 2 black ones?
I have 3 wires, 2 black and also a colored one!
Would the colored one be a ground?
So:
The one of the pump clutch goes also to the Idle actuator to increase engine speed I think.
The other +12V is on the fuse box, and supplied from the car loom +12V.
450sl
« Reply #3 on: June 05, 2018, 16:25:07 »
Yes the 2 black wires. Ground can be determinayed by measuring continuity.
Thierry du Laos
« Reply #4 on: June 06, 2018, 08:58:08 »
I hope the colored one is a Ground.
Sounds strange to me, because its not a brown, but  red !!!
An other that I don't find logic, is the smaller black supplies ALL (Fans, compressor, Idle ..).
And the big one goes ONLY to the compresseur and Idle actuator?
Do I miss something?
I'll measure, thanks a lot.
450sl
« Reply #5 on: June 06, 2018, 13:51:24 »
hope this helps
Thierry du Laos
« Reply #6 on: June 07, 2018, 03:05:26 »
Great, 450SL,
I measured yesterday evening the wires and it confirmed your info.
I connected, and its nice to see the A/C working since I bought and restored the car.
This week end I will refill the circuit.
Thanks again also for the schema
Thierry from Laos
