Author Topic: Lock compensation differential or limilted slip diff  (Read 1799 times)
cfm65@me.com
  • Cape Town, South Africa
« on: June 10, 2018, 13:35:29 »
Hi Gents,
Mercedes calls it a ‘lock compensation differential’ which I assume is what is commonly known as a limited slip diff.
My 250SL has a 3.69 rear end, which is supposed to be ‘optional equipment’
My question, how could I determine if this is a limited slip diff or not?
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Re: Lock compensation differential or limilted slip diff
« Reply #1 on: June 10, 2018, 15:17:01 »
One thing I recall is to jackup the car so you have both of the rear wheels off the ground. Then turn one of the rear wheels by hand. If the other wheel turns in the same direction it is limited-slip. If the other turns in the opposite direction it is a regular diff.
cfm65@me.com
« Reply #2 on: June 10, 2018, 18:05:37 »
TKS Jonny,
I’ll give a go and let you know.
Much appreciated.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
hkollan
  • Spain, Castilla-La Mancha
« Reply #3 on: June 11, 2018, 13:44:33 »
A LSD diff would also have a metal plate bolted to the rear of the differantial housing, with the instructions to only use oil for a limited slip differential engraved.
Hans
« Last Edit: June 11, 2018, 22:42:29 by hkollan »
Hans K, Cuenca, Spain
cfm65@me.com
« Reply #4 on: June 11, 2018, 19:48:54 »
TKS Hans,
Much appreciated, I have not noticed the bolted plate you mention. I’ll have another look in the morning.
I am in the process of replacing the torque converter. The prop shaft is disconnected and therefor, as yet, I cannot determine if I have a LSD or not. However, I will report back ASAP.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
