Hi, thanks for all the suggestions. Today I put the trigger points back into the distributor and got that back onto the original setting, thanks for the advice regarding removal and replacement. I have also checked the resistance of the air intake and the engine water temperature sensors against the BBB specs and they are ok. I also checked the resistance etc on the MAP valve on various pins according to
https://oldtimer.tips/en/d-jetronic/72-troubleshooting, and they checked out ok.
I like the idea of the smoke machine for checking the vacuum but at this point will have to locate a garage with one locally.
In the meantime I also think it has something to do with the fuel delivery system. According to the BBB the fuel pump should be able to deliver 120L/hr or 2L/minute at 2 BARG (30psi). Where would you recomend I connect to the fuel system to check this flow rate, is it ok draining it open ended into a bucket to check the flow or does it have to be at pressure?
Finally it is worth noting that the car was running trouble free until I took it off the road and replaced the front and rear rubbers etc on the trailing or radius suspension arms. because I don't have a car hoist I had to jack up each side of the car quite high to release the rear springs, one side at a time. I have checked and haven't damaged any of the fuel lines in doing this, however after completing this job I only got a short run in and parked the car. The next morning large clouds of gray smoke came out of the exhaust but cleared and I did a short run in the car, however the next day the engine really developed the missing and back firing.
It may be a coincidence, I can't think what might have caused it, however despite having drained the petrol tank already I am going to drain it again and take the tank filter out and clean it. If it has a lot of crud in it I may take the tank out itself.
