Author Topic: Data Card questions  (Read 2535 times)
eric@genevacleaners.com
Data Card questions
« on: June 22, 2018, 18:51:46 »
I have been working on my data card info and I could use some help.  My data card is the version 2 in the technical manual and I would like to know more about the Auftrags-Nr box (or box e from the technical manual).  My number is 77193888.  The box marked J on the manual or Ueberahmetag has a date of 12 Sept 1967 stamped.  I understood that this car was a European delivery or an American ordered car.  Can anyone help me understand if these numbers tell that same story?  Thanks
Re: Data Card questions
« Reply #1 on: June 22, 2018, 19:40:54 »
I like this kind of puzzles...
Why would you conclude it is Europe or America? The code is 719 - this is St Pierre Et Miquelon, close, but not America, it is a French territory, actually. I think you have quite an exotic car by place of ordering...
« Reply #2 on: June 22, 2018, 21:16:17 »
The last 4 digits of the Auftrags-Nr may hold some of the answers.  I can’t quite figure them out.  Both the body and paint number plate on the car and the data card indicate that this is a U.S. Version car (419).  The Ueberahmetag has a date stamped of 12 Sept 1967 and as the Tech Manual states that was only done in a “few markets ie Germany”.
« Reply #3 on: June 22, 2018, 22:08:30 »
Auftrag nr is just order number. Last for digits is just sequence. Not sure what you mean by 419, but it is quite likely that in Mercedes nomenclature/classification US cluster is same as the St Pierre islands cluster (or South America), which number is 7.
Ubernahmetag - delivery date, yes, the Technical Manual says what is says, but the example of the version 2 data card is the US data card and it has this date.
Your order number is 77193888, so the 2, 3 and 4th digits that are showing the market are 719 and this is St Pierre. On your paint code plate you probably have 7 (market cluster).
This is what I would think. Not too many Pagodas ordered in St Pierre Et Miqquelon islands...
ejboyd5
  • Southold, NY
« Reply #4 on: June 22, 2018, 22:37:54 »
We went through this destination several years ago as I remember dong some research on the subject. Do a site search for  St Pierre Et Miquelon  and bring yourself up to speed.
« Reply #5 on: June 22, 2018, 22:59:25 »
ejboyd5, thanks, I did, I found my previous post....
