Author Topic: 15 Watt bulbs for reverse lights  (Read 3782 times)
rutger kohler
« on: July 10, 2018, 08:13:48 »
Hi, I need to replace one of my reversing light bulbs (15Watt).  They are no longer supplied by most stockists down here, with 5, 21 and occassionally 10W being the only choices. What should I replace them with plse?  I have no great wish to repalce them with LED's at the moment.
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
ejboyd5
  • Southold, NY
Re: 15 Watt bulbs for reverse lights
« Reply #1 on: July 10, 2018, 11:32:38 »
If you ever drive the car at night and use the reverse light to assist, go with the LEDs. You will be surprised by the improvement.
scoot
  • USA, CA, Altadena
« Reply #2 on: July 10, 2018, 14:57:01 »
That depends very much on your choice of LEDs.  Some of the newer ones are pretty good.  Some of the earlier ones not so good.  What specifically did you use in your car?
Scott Allen
'67 250 SL (early)
Altadena, California
ejboyd5
  • Southold, NY
« Reply #3 on: July 10, 2018, 18:57:33 »
Replaced 1156 back-up lamps with 1156-CW27-T ( lamps $14.95 each from Super Bright LEDs Inc.) https://www.superbrightleds.com/
Iconic
  • USA, IL, Highland Park
  • ex-Membership Administrator
« Reply #4 on: July 10, 2018, 20:16:52 »
Back to Rutger's original question (he's not interested in LED at this time):
Use the 21 watt. In fact, the bulb is supposed to be a 21 watt bulb, not 15. Additionally, some people use the 1156, which is typically 25 watts, so for you, going from 15 to 21 will be fine. All, please correct me if I am wrong.
1998 BMW M-Rdstr Estoril Blue
rutger kohler
« Reply #5 on: July 10, 2018, 21:25:57 »
Hi, thanks for all the replies.  I will fit a 21W bulb, however the tail light fitting clearly has 15W stamped on it where the reverse light goes. Also the Hynes teardowm manual, for what it's worth, also specifies 15W.
cheers
Rodger K
1972 280SE 3.5 auto
mtoomey
  • USA, MA, Cohasset MA
« Reply #6 on: July 10, 2018, 21:33:11 »
I'd be wary of a conventional 21W bulb due to heat.  If extra brightness is required, look at the LED option.  Superbright is a good outfit; I've used them a few times..
« Reply #7 on: July 10, 2018, 21:38:26 »
I have 21W too, see no traces of heat issue. Perhaps during a very long drive on reverse. I think, however, LED is the best way. Reverse light is all about as bright light as possible, I think.
« Reply #8 on: July 10, 2018, 21:38:50 »
Mark,
take a look here: https://www.sl113.org/wiki/Electrical/TailLights
Obviously Rutger is correct, the back-up light (reversing light in his language) is a 15W bulb.
Iconic
« Reply #9 on: July 11, 2018, 19:59:12 »
Thanks for the correction Alfred.
15 watts is the spec. Interesting. I hadn't seen that before.
I'll check mine to see if they are original.  ;D
I would still choose 21 watt as a replacement instead of 5 w or 10 w, if the 15 w was not available.
Mark
