Author Topic: 5-Speed Shift Linkage Bushings  (Read 1580 times)
Atazman
  • USA, Ca, Pleasanton
« on: July 10, 2018, 15:41:11 »
Does anyone know if the shift linkage bushings for a 5-speed are the same as for the 4-speed manual shift?  Same parts for replacement?
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
Re: 5-Speed Shift Linkage Bushings
« Reply #1 on: July 10, 2018, 20:21:48 »
Same parts. Everything looks a bit different but comes apart the same way.
« Reply #2 on: July 10, 2018, 21:13:18 »
These are the only parts I found for ZF 5 speed in EPC.
Atazman
« Reply #3 on: July 11, 2018, 01:47:52 »
Thanks for the confirmation, Pawel and Benz Dr.  Appreciate you taking the time to investigate and respond.
Don
67 250 Sl
(#3168) from Italy
George Des
« Reply #4 on: July 11, 2018, 12:31:49 »
Yes, parts set up is the same. The difference is in the length of the three rods that go from the shifter to the box.
