Author Topic: Heater operation  (Read 2281 times)
Jimmyhag
Heater operation
« on: July 15, 2018, 15:18:49 »
I recently completed a restoration of my European model '69 280SL. I'm not familiar with the position of heating levers and  blower knob. It's summertime and it seems there is a constant rush of hot air at my feet. Maybe just the hot weather but I would appreciate any suggestions to have no air being blown either at my feet or on the windshield.
Re: Heater operation
« Reply #1 on: July 15, 2018, 15:43:46 »
Here ya go, the search function is your friend.
https://www.sl113.org/forums/index.php?topic=8613.msg55998#msg55998
« Reply #2 on: July 15, 2018, 15:51:33 »
My advise would be to check all the openings in the firewall and grommets - all the wires, cables, pedals - there are plenty of them there, particularly on the driver's side.
« Reply #3 on: July 15, 2018, 18:04:11 »
Did you read the instructions in your owner's manual?
https://www.sl113.org/forums/index.php?topic=12018.msg81775#msg81775
« Reply #4 on: July 16, 2018, 05:22:34 »
You might also pop the engine firewall grommet off so you can see if the heater water valve is opening and closing when you move the lever.
