Author Topic: brake cover plates missing?  (Read 2683 times)
« on: January 16, 2005, 19:53:26 »
This weekend I started to replace the brake discs and pads.  On all 4 of my brake calipers, there are no cover plates in front on the brake pads (on the calipers).  Should there be cover plates on the front and back?
I am also having to do the caliper repair kits on the rears.  Does anyone have any advise on doing this?  Anything to do, not do....
Thanks!
Memphis, TN.
1997 E320
Re: brake cover plates missing?
« Reply #1 on: January 16, 2005, 20:09:41 »
Hi Bob,
There is supposed to be a rectangular cover plate on the caliper which snaps in place to conceal the outer edge of the brake pads and rotor.  Sorry I don't know anything about the rebuild kit.
« Reply #2 on: January 16, 2005, 21:18:49 »
Hello Bob,
Mercedes discontinued using these plates at some point. I do not know if it was before or after the end of W113 production.
They found that they served no important purpose. In fact they actually hindered air flow and cooling of the brake calipers and rotors. Later Mercedes cars used the same caliper/rotor configuration and never had these covers.
Also I do not recall ever seeing them on rear calipers? coments?
« Reply #3 on: January 17, 2005, 06:35:44 »
When I removed the rear brakes calipers, I noticed that there is a high side and a low side to the pistons.  On my calipers, one of the pistons had the high side up, and the other piston (same caliper) had the high side down.  Reading the BBB, it says to have the high side of the piston down, this reduces brake noise.
Does anyone have any opinion or comment on this?  Both pistons the same direction (down) ... or ... alternate, one up and one down?
I just want to do it right and only do it one time.
Thanks all!
Memphis, TN.
1997 E320
