Author Topic: foot dimmer on first made Pagoda's  (Read 3881 times)
free2keun
« on: July 21, 2018, 06:12:29 »
Hello, was there a foot dimmer placed on the first made Pagoda's ?  I can't find the high beam headlight switch.
the problem is that the high light only works when I trow the column switch..
and the other problem is that the low lights doesn't work.. :-(
so i have to ride with the fog lights on
or weren't the first Pagoda's equipped with the high beam headlight switch.. ?
CCollum
Re: foot dimmer on first made Pagoda's
« Reply #1 on: July 22, 2018, 14:01:46 »
My 64’s high beam switch is on the floor, activated by my left foot. I have a LHD.
« Reply #2 on: July 22, 2018, 14:09:15 »
When you look into EPC, you have early PN A0005451112 then a later one A0005451212. There is no information "As of chassis...." - nothing like that. That would suggest it was there, but this is a theory.
free2keun
« Reply #3 on: July 23, 2018, 07:35:29 »
Thank You Pawel66 and CCollum.  It is right.  From the beginning, there was a foot dimmer.
Yesterday, I looked for about 4 hours for electrical wiring of the foot dimmer..  and found nothing.  No white or yellow wire that was lost, loss or cut off.  Also the withe/yellow that that starts from the light switch..  I don't see it elsewhere..
On the fuses, I see a big white arriving and a small going away, also a big yellow and small yellow (they go to the front lights)
« Reply #4 on: July 23, 2018, 08:03:52 »
Well, perhaps one of the POs just slaughtered the wires and connected power feed from light switch to high beam power supply, omitting the dimmer switch. Then it is just a matter of finding the appropriate wires with multimeter or routing them again.
It sounds like you have the wiring diagram.
