Author Topic: People who paint wiring harnesses...  (Read 2330 times)
« on: July 21, 2018, 17:11:55 »
People who paint wiring harnesses when they paint a car so whomever restores the car at a later date has to spend hours getting the paint back off should be shot.
Re: People who paint wiring harnesses...
« Reply #1 on: July 21, 2018, 18:47:11 »
I suppose they would have to stand in a que of those responsible for other malpractices...
mnahon
  • Canada, QC, Montreal
« Reply #2 on: July 22, 2018, 13:27:30 »
I think the first in line should be those who put black tar undercoating on the bottom of the car.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
mbzse
« Reply #3 on: July 22, 2018, 13:36:15 »
Quote from: mnahon
.../... those who put black tar undercoating on the bottom of the car
I have been the victim of that a number of times (shudder...) I loathe that practice.
Dry ice treatment will take it away; at great effort&cost
https://www.youtube.com/watch?v=40ULvuC7SiM
« Last Edit: July 22, 2018, 13:46:30 by mbzse »
/Hans S
mnahon
« Reply #4 on: July 22, 2018, 18:47:49 »
Thanks Hans, yes I did the dry ice a couple of summers ago. I now have to get some rust repaired (that was thriving under the undercoating) and then proper underbody paint. By the time it's all done, a lot of time, money and effort.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
« Reply #5 on: July 22, 2018, 19:38:43 »
Perahps a list of fatal typical malpractices would be useful here...
We could then vote the place in the que...
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #6 on: July 25, 2018, 17:57:30 »
Black tar... I think I had one guy who had used actual asphalt, it was like the roofing sheets stuff it had granules(small rocks) in it and it was covering the whole underside lines and all.  He also had sprayed I think expanding foam in between panels. I was soooo tempted to track him down and make him try and take it all off.
Bob "Baron" Youngman
1965 220se coupe restomod
« Reply #7 on: July 26, 2018, 08:33:33 »
Mine was so bad underneath that my friend that did the welding would bog down and stop at the point where there was tar to be removed away from seams or many spot welds to grind so I would fly up there for a couple 14 hour days with a grinder and a cupped wire brush and clear a path for him to work.  Luckily i didn't have to take it all off as we sent it to be baked and E-coated but getting that stuff off was horrid.
The wiring harness is coming along nicely.  I tested a few areas using paint stripper and after finding out the stripper didn't effect the plastic sheaths or wire insulation things are flying along.
