Author Topic: Wiring loom Tape  (Read 2430 times)
Mike Heagney
Wiring loom Tape
« on: January 17, 2005, 04:00:58 »
Hi to all'
My wiring loom is held together with plastic electrical tape.I am trying to rebuild the car as close as possible to factory finish, and wonder what was used to bind the loom originally.
What was the material (cloth style friction tape ?)or its closest modern day equivalent, and information on a supplier.
It will need to be rebound in something,what do the top restoration shops use?
Many thanks,
Mike
64 230 auto,RHD....in boxes.
George Des
Re: Wiring loom Tape
« Reply #1 on: January 17, 2005, 07:00:26 »
Mike,
My 67 230Sl Euro had three types of loom covering. Most of the loom was covered with a vinyl tubing, but in several areas it was covered with a cloth type friction tape. There were also some areas covered with a very thin vinyl wrap. The frition tape and vinyl wrap are available from Eastwood. The tubing is available through Rhode Island Wiring Service. If you do a search you'll find several discussions on the rebuilding of the wiring harness which includes discussions of the coverings.
George Des
« Reply #2 on: January 17, 2005, 10:04:28 »
take a good look at the extensive (and growing) number of pics of my original, unrestored '64 230SL RHD at www.realnoteguitars.com/merc , and feel free to ask for more!
Neil Rote (Australia)
'64 230SL unrestored 4-speed
« Last Edit: January 17, 2005, 10:05:02 by n/a »
