Author Topic: indicator /wiper stalk for 230sl  (Read 6450 times)
mgmoore
  • United Kingdom, England, cheltenham
« on: July 23, 2018, 09:17:36 »
Looking for an indicator/ wiper stalk for my 67 230sl. Needs to be in good shape and working.
Mathew
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Re: indicator /wiper stalk for 230sl
« Reply #2 on: July 23, 2018, 17:03:20 »
...I'm not sure if it's the correct one for you. ...
Incorrect for all W113!
Palm Beach Classics
  • USA, FL, West Palm Beach
    • Palm Beach Classics
« Reply #3 on: July 25, 2018, 13:34:42 »
I have them in stock!
This is correct for W113.
$600 plus shipping.
give me a call 561-568-8882
mbpaul
  • USA, NM, Albuquerque, NM
« Reply #4 on: July 25, 2018, 16:50:25 »
The picture is labeled as a 280SL part.  mgmoore wanted a 230SL part.  The 280SL and 230SL parts are different and will not interchange.
Palm Beach Classics
« Reply #5 on: July 25, 2018, 17:55:38 »
The only difference between the 230sl and 280sl combination switch is the kink in the stalk. Many people replace the stalk with the 280SL stalk because it is slightly longer as well as about half the price of the 230SL stalk. They are interchangeable.
mbpaul
« Reply #6 on: July 25, 2018, 19:23:43 »
Not according to the technical manual.
www.sl113.org/wiki/Electrical/SteeringColumnSwitch
Which says:  "The 230SL switch unit is different from the 280SL switch unit and the two are NOT interchangeable!"
mgmoore
« Reply #7 on: August 06, 2018, 21:05:25 »
Just back from my vacation and noticed the feedback, great. Does palm Beach classics have any customers that can verify unit is interchangeable. Iv'e spoken with a couple of sl guys and they are of the opinion that the 230sl switch is different and the 250/280sl unit can't be used?Thanks,
Mathew.
« Reply #8 on: August 08, 2018, 23:22:53 »
Nope !
I fully support Paul's view to the things.
Quote
The both stalks do not interchange !
The 230ies (and early 250ies) do need the A001 545 5524 stalk and not the later A002 545 2924, which is only correct for the late 250ies and the 280ies.
They are different, the 280 unit is too angulated
and would interfere with the (230ies) steering wheel if used.
Both are attached (fixed) to the steering column jack at different positions,
that's why the stalk is different.
Don't use the 280 unit on a 230 ... unless you are crazy.
Palm Beach, I can understand your willingness to sell a (pricey) part,
but it doesn't make sense for mgmoore's car.
Go and get a correct one from Mercedes-Benz (Tom Hanson) instead.
Or a Chinese aftermarket part - should also work.
But not a 280 SL stalk.
(04/69 - (used) column stalk collector)
