Author Topic: Thermo Time Switch  (Read 31227 times)
teahead
  • USA, WA, Des Moines
  • aka "Rob"
Re: Thermo Time Switch
« Reply #25 on: August 11, 2019, 19:08:45 »
Well...I installed the new TTS and still, no power going to the cold start valve (CSV) while cranking.
Guess I gotta do more testing.
jpringot
« Reply #26 on: October 19, 2019, 13:20:18 »
Hello
In this thermo swich on ebay with connector
where is the w and the g? or on the connector ev1 red or black ?
« Last Edit: October 19, 2019, 13:25:11 by jpringot »
teahead
  • aka "Rob"
« Reply #27 on: October 19, 2019, 17:10:00 »
Hello
You're talking about the switch 91161711700?
It's labelled.  Can't miss it.  As aforementioned, you take off those pegs that are on there and install the screw hole nuts.  Very easy.  W & G are labelled.
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« Reply #28 on: November 20, 2021, 14:23:37 »
Hi gents
I'm having trouble with my TTS and puzzled about the prices of such a device
Searching on the net I found a possible part that could fit: https://vdo-webshop.nl/en/temperature-switches/825-vdo-temperature-switch-35c-m14-4103590689283.html
But as you may have seen only one connection is available while I have 2 cables
I was wondering wether the ground cannot be inserted between the washer and the thread ?
Would it work like that ?
Thanks !
1965 230 SL
1991 Porsche 911/964 carrera 2
My youtube channel #lfgdf
mnahon
  • Canada, QC, Montreal
« Reply #29 on: November 20, 2021, 14:40:28 »
Hi Figoulu,
That switch is quite different in function. It will simply turn on or off at 35C.
The function of the TTS on our cars is more complicated. It's intended to energize the cold start valve for a duration of time. When the engine is cold, that duration is ~5-10 secs. The duration decreases as the coolant temperature increases. Eventually, at around 35C, the duration drops to zero.
You can find, in the technical manual, a more detailed description:
https://www.sl113.org/wiki/Restricted/Engine-starting-aid-tour
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
« Reply #30 on: November 20, 2021, 16:26:00 »
There were numerous threads about replacements of various types. Of course you can find original replacement, it will be horrifyingly expensive.
I used the modern Bosch Bosch replacement as shown on attachment. Part number will be e.g. F026 T030102. And connectors - at the bottom of the table.
Figoulu
« Reply #31 on: November 20, 2021, 17:43:06 »
Thanks Pawel
Still 130€ appeared high enough to find an alternative…
I understand it’s not really possible to spend less 😅
1965 230 SL
Figoulu
« Reply #32 on: November 20, 2021, 18:00:16 »
Additionally Pawel, considering the small differences between 100, 101, and 102, can i freely go for one of these without any issues ?
« Last Edit: November 20, 2021, 18:19:28 by Figoulu »
1965 230 SL
« Reply #33 on: November 20, 2021, 18:08:19 »
I think indeed that it would be difficult to spend less...
They are the same in terms of dimensions. I do not remember which one I have, I think 102 and it works very well. It is important during hot start when you have your car tuned so that it does not run too rich, spark plugs being light tan. Then hot start may be an issue.
Just my opinion.
Figoulu
« Reply #34 on: November 20, 2021, 18:20:28 »
Just my opinion.
Having read the starting aid topic, the right timing on my TTS is finally 9.5s
So 101 is the most accurate while the other ones are not totally out of the scope…
« Last Edit: November 20, 2021, 18:56:19 by Figoulu »
1965 230 SL
Figoulu
« Reply #35 on: November 20, 2021, 20:21:46 »
Found one on ebay
NOS for 110€ postage included…
Ref is 100 which apparently is equivalent to 102
1965 230 SL
« Reply #36 on: November 20, 2021, 20:41:33 »
Excellent!
I bought mine a couple of years ago form Bosch service nearby, just ordered via email.
Figoulu
« Reply #37 on: November 21, 2021, 07:57:00 »
Excellent!
I checked before all, but they are no more providing stocks on those refs
1965 230 SL
« Reply #38 on: November 21, 2021, 10:17:42 »
I see, good to know...
MarkCan
  • Canada, Ontario, Mississauga
« Reply #39 on: November 22, 2021, 01:45:50 »
It is with pleasure that I’m reading this thread. Finally something that I need for my rebuild is in the parts lot and appears to be in good working order. 👍
« Reply #40 on: November 22, 2021, 06:20:02 »
That is a money and trouble saver if so :)!
Jean-Philippe Ringot
  • France, Île-de-France, CLAMART
« Reply #41 on: March 30, 2022, 12:08:46 »
Bonjour,
Je viens d'acheter le thermo time switch Réf.: F 026 T03 101 quelqu'un peut il me dire le branchement sur les cosses du fil rose/bleu et le fil rose ? Merci
« Reply #42 on: March 30, 2022, 13:08:36 »
Quote
I have just bought the thermo time switch Ref.: F 026 T03 101 can someone tell me the connection to the terminals of the pink/blue wire and the pink wire? Thank you
Check this: https://www.sl113.org/wiki/Engine/ThermoTimeSwitch
Item 32 on the wiring diagram: https://www.sl113.org/wiki/Restricted/ColorWiringDiagrams
Pink (rose) goes to W
Pink/Blue goes to G
« Reply #43 on: March 30, 2022, 14:05:45 »
Bonjour,
You have the drawing of the connectors of the new TTS in reply no. 31 in this thread.
Pink/blue to plus (G on the old TTs).
Pink to signal (switch symbol, W on the old TTS).
« Reply #44 on: April 01, 2022, 09:54:01 »
Merci beaucoup ! J'ai pris le BOSCH F 026 T03 101 pour ma 280sl/8 1968 ! Ai je fais le bon choix pour ma pagode ? Merci
mauro12
  • Italy, Sicily, Messina
« Reply #45 on: November 30, 2022, 00:04:47 »
Hi guys , just a quick word about this tts .
I was checking on eBay and the size seems to be higher and the probe smaller in size . There is no risk of touching the coolant pipe with the terminal connectors ? Can you post a picture of this sensor in your car ? Thank you
Mauro Pisani
250sl 1967 5speed zf manual
mauro12
« Reply #46 on: December 08, 2022, 17:48:25 »
Any help from somebody ? i guess this type of sensor is good but maybe some modifications are needed , like it seems to be much higher that the original and the wire connection is very close to the coolant pipe above . Any pictures ? thank you
Mauro Pisani
Figoulu
« Reply #47 on: April 30, 2023, 06:22:45 »
Hi all
I'm about to plug my TTS but the electrical connector provided with the bosch part need to replug the original connector
Anybody knows the type of connector (Iso ?) that I need to purschase to match Bosch plug ?
1965 230 SL
BobH
« Reply #48 on: April 30, 2023, 08:11:30 »
Hello, the part numbers for the connector are on this thread if you have a look back at earlier posts
There's a picture and instructions on here
https://www.sl113.org/wiki/Engine/ThermoTimeSwitch?action=download&upname=W113%20Cold%20Start%20Thermo%20Time%20Sensor%20Alternative%20rev%201.pdf
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Figoulu
« Reply #49 on: April 30, 2023, 14:46:43 »
Ohhhh thanks and sorry 👍👍
1965 230 SL
