Author Topic: Centre of rotation  (Read 2908 times)
Mike Heagney
Centre of rotation
« on: January 17, 2005, 04:15:30 »
Hi again,
After replacing structural floor panels I want to place the body shell on a rotisserie.
Has any group member done this. Finding an axis line through the body shell in order for it to rotate smoothly is somewhat of a guess.
A measurement at relevant positions,front and rear, would be a big help from anyone who has done the exercise.
Cheers,
Mike.
64 230 auto. RHD...in boxes.
Re: Centre of rotation
« Reply #1 on: January 17, 2005, 06:01:31 »
Hey Mike
Have a look at this topic
http://index.php?topic=944
there are some photos for you to look at
Malc
« Reply #2 on: January 17, 2005, 06:20:23 »
Mike,
Although I have not put the old girl on the barbie yet I have done this with a couple of other cars: MGA and BMW 2002Tii
In both cases I found that the bumper level is about the right place
The BMW shell tended to want to sit upside down, but the balance was close enough to be able to rotate it easily by hand.
However I did NOT attach my homemade system to the bumper mount points as they are a bit weak especially the rear of the BMW 2002.
I made up arms which passed through various apertures and then bolted onto the shell at strong points. So at the rear the arms were "cranked" through where the lights are, down through the boot floor where the tank usually sits and then attached to the rear axle mounting points. At the front I went through the grill area and then made a bracket to where the engine subframe bolts on. All looked abit ugly but worked!
Make sure that the car is high enough so it will rotate through 360 degrees. I made "locks" on my system to prevent it rolling when being moved up and down.
Cheers
Malc
« Reply #3 on: January 17, 2005, 08:00:23 »
Originally posted by Mike Heagney
Hi again,
Mike,
In addition to the link provided to the Group Member who has done this, you might want to contact restorers and ask how they do it.
http://www.silverstarrestorations.com/tour.htm
http://www.silverstarrestorations.com/services.htm
Mike Heagney
« Reply #4 on: January 18, 2005, 03:32:00 »
Thanks for the very useful info Rod, Malc and Bob.
After the structural floor sections have been fixed,I intend to use the bumper mounts to hold the car.
At the moment it stands on the rear axle and a 60 litre drum holding the trans tunnel where the gear box lived.
When still on 4 wheels I made braces to each door opening to prevent any flexing.
I,ll post some photos when ready.
Cheers,
Mike.
