Author Topic: Dash speaker mount kit  (Read 2461 times)
Mike H
  • Australia, New South Wales, East Ballina
« on: July 30, 2018, 10:49:45 »
My car came without a dash speaker and the hardware to attach it.
I bought a dash speaker mount kit from SLS to fit my new speaker but it came without instructions.,
Has anyone fitted a speaker kit recently and have a photo showing the setup?
Thanks for any help.
Mike.
mbzse
Re: Dash speaker mount kit
« Reply #1 on: July 30, 2018, 11:46:56 »
Quote from: Mike H
.../...speaker kit recently and have a photo showing the setup.../...
The Technical Manual on this website is your friend... Excellent description there
https://www.sl113.org/wiki/Electrical/Speakers
/Hans S
Mike H
« Reply #2 on: July 30, 2018, 12:13:17 »
Thanks so much Hans.
Mike
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #3 on: July 30, 2018, 14:26:55 »
Make sure the heater levers work after you mount the speaker.  It is very tight.  I took mine out last week to see why the top right lever got stuck and the speaker was binding and needed shims.  All better now...
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
mbzse
« Reply #4 on: July 30, 2018, 14:33:26 »
Quote from: badali
.../...very tight.  I took mine out last week to see why the top right lever got stuck and the speaker was binding.../...
You need not shim the speaker.
One of the plastic heat lever wheels (top right one) has the protuding plastic milled off from factory; in order to clear the speaker.
However, on aftermarket lever wheels, this is not so when delivered/sold, and you need to cut the part yourself before installing.
We credit JoeA with the illustration!
« Last Edit: July 30, 2018, 17:26:58 by mbzse »
/Hans S
« Reply #5 on: July 30, 2018, 16:46:28 »
Who to credit for the illustration? You Alfred E?
No, photo and instructions were provided by JA17.
Mike H, take a look at the photo of the speaker kit that Authentic Classics sells, perhaps you can figure out how to mount the speaker:
https://www.authenticclassics.com/Dash-Speaker-Inst-Hardware-Kit-230SL-250SL-280SL-p/auth-005372.htm
« Last Edit: July 30, 2018, 16:51:40 by 66andBlue »
Mike H
« Reply #6 on: July 31, 2018, 10:03:24 »
That's a big help.
Thanks Alfred.
Mike
