Go to the search function, use "key" and search the general discussion forum subject line only. You will get about ten hits, the one with 17 replies should give you the answer and a bit of discussion.
Early cars do not have the single key; ignition, doors, glove/trunk, potentially the gas cap, if it is keyed. But check the string for the full story.
