Become a
Full Member
Emergency Contact List
Any one know where I can order bushings for pinion bolt?
Topic: Any one know where I can order bushings for pinion bolt? (Read 1513 times)
CJHenderson
Full Member
Silver
USA, AR, Benton
July 31, 2018, 19:33:23 »
Where can I order bushings for the pinion bolt? The bushings are in worn condition and one will not budge from the pinion bolt.
1950 MG-TD
Vendor
Platinum
Canada, ON, Port Lambton
Re: Any one know where I can order bushings for pinion bolt?
July 31, 2018, 20:35:46 »
Readily available. I've changed a lot of them. Sometimes have to change the brass ones in the axle pivot as well.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
