Become a
Full Member
Emergency Contact List
Engine Backfires on idle
Topic: Engine Backfires on idle (Read 1785 times)
RichieScotland
August 05, 2018, 18:57:35 »
Hi
My 230SL has started to backfire on idle and is running rough. I have tried adjusting timing which looks correct - any ideas where to go next - injectors? injector pump ? valves ? Any clues gratefully received !
thanks
Richie
Rolf-Dieter ✝︎
Associate Member
Platinum
Canada, ON, London
Re: Engine Backfires on idle
August 05, 2018, 19:45:11 »
I recommend to first check your linkages
Here —— >
https://www.sl113.org/wiki/Restricted/Linkage-tour
Mike K
Inactive
Silver
South Africa, Gauteng, Johannesburg
Reply #2 on:
August 06, 2018, 20:32:25 »
Check that your ignition cables are not faulty as well as spark plugs.
This can also be a cause, especially the rough running.
Mike
Feb. 1971 Mercedes 280SL Auto LHD (Last of W113 Series)
http://michali.zenfolio.com
