Author Topic: boot lock  (Read 3117 times)
do8erman
  • United Kingdom, England, Ware
boot lock
« on: August 08, 2018, 10:55:57 »
On taking my boot /trunk lock apart for chroming the alloy 3mm thick retaining washer had the tab broken.  Before attempting to make one can these be purchased? Rebuilding a 230 r/h drive purchased in the last few weeks and found this site invaluable thanks to all who contribute
Re: boot lock
« Reply #1 on: August 08, 2018, 14:03:03 »
Usually a picture helps if possible. Quite a few of us have a stash of parts here and there and might be willing to send you one.
do8erman
Re: boot lock
« Reply #2 on: August 08, 2018, 15:48:22 »
Photo attached.  Thanks for your quick response.  Also would you know if the attached drawing for a TR5 is available for a 113 as I would like the dimension from A post to B post?
neelyrc
  • USA, AL, Birmingham
Re: boot lock
« Reply #3 on: August 08, 2018, 20:29:17 »
do8erman,
Some dimensions here in the technical manual.  Don't know if you will find what you are looking for. Have a look.
https://www.sl113.org/wiki/ChassisBody/Chassis
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
Re: boot lock
« Reply #4 on: August 08, 2018, 23:35:35 »
Quote
retaining washer
Hello Doberman,
the pot metal retainer ring in the trunk lock assembly has never been available separately
as haven't the ones in the door locks.
Only way to solve this issue is to get an old replacement trunk (boot) lock with an unbroken ring.
A sedan's boot lock should work as parts donor as well.
