Author Topic: Compressing the cylinder in the caliper  (Read 1413 times)
Big Yellow
  • France, Provence-Alpes-Côte d'Azur, Roquefort les Pins
« on: August 12, 2018, 15:38:43 »
Hi all,
I need a little advise on how to compress the cylinders on my front brake caliper. The brakes on the left side siezed up and I needed to take a look at the disc and pads. Once I loosened the caliper I got the pads out, but I don't seem to get the cylinders to retract... They moved out when I pushed the brakes, but they wont go back. I have opened the bleed nipple, and brake fluid is coming out, but the cylinders are totally stuck... The nipple to the brakeline is not budging so I can't get the calipers out, which makes it impossible to get a clamp in because of the disc... I can't understand why the cylinders don't retract back...? >:(
Any advise welcomed.
/ BY
Vidar "Big Yellow" Holmdin
MB 230 SL - 1964 manual
hkollan
  • Spain, Castilla-La Mancha
Re: Compressing the cylinder in the caliper
« Reply #1 on: August 12, 2018, 17:07:00 »
You need a piston retraction tool.
Here is one that I've used for this purpose.
Not the best quality but might last for a while if not abused.
Hans
Hans K, Cuenca, Spain
