Author Topic: WRD Part Missing?  (Read 3168 times)
Kevkeller
  • USA, HI, Honolulu
WRD Part Missing?
« on: August 13, 2018, 06:40:14 »
A few months ago I took apart my WRD and I am putting it back together.  I think I might be missing a part.  Can anyone confirm?
I am thinking it is #3.  I don't know where the part might have gone though.
Thanks,  Kevin
1970 280 SL
450sl
Re: WRD Part Missing?
« Reply #1 on: August 13, 2018, 07:32:34 »
yes you are missing the steel ring .
« Reply #2 on: August 13, 2018, 13:14:46 »
Was this engine running before you took it apart?  When you add the ring, the cold running mixture will be richer.
Kevkeller
  • USA, HI, Honolulu
« Reply #3 on: August 13, 2018, 13:36:45 »
Yes it was running but a couple of the plungers seized up after sitting so long so I had to remove the pump.
1970 280 SL
« Reply #5 on: August 13, 2018, 21:55:49 »
Looks like this.  Unfortunately I don’t have a spare.  If memory serves you have a lathe?
OD:  1.102”    28mm
Total thickness:  0.20”    5.1mm
ID of recess: 0.867”     22mm
Depth or recess:  0.119”   3mm
If you look closely there is a little 45 degree chamfer on the ID at the bottom of the recess.  All other edges deburred only.
Kevkeller
  • USA, HI, Honolulu
« Reply #6 on: August 14, 2018, 02:33:31 »
Thanks!  I do. Is it aluminum?
You the man.
1970 280 SL
Dash808
  • USA, HI, Kaneohe
« Reply #7 on: August 14, 2018, 04:12:42 »
Hey Kevin, I'm not far from you if you need one for reference  :)
Chan Johnson
'67 250sl
Napoli Italian Euro
Bang Bang Booogie!
Kevkeller
  • USA, HI, Honolulu
« Reply #8 on: August 14, 2018, 08:25:44 »
Thanks Dash.  I almost hate to admit it but I recently bought a spare FIP. I just didn’t want to take it apart if I didn’t have to.
Where do you live anyway?  I’m in St Louis Heights on Oahu.
1970 280 SL
hkollan
  • Spain, Castilla-La Mancha
« Reply #9 on: August 14, 2018, 10:39:10 »
It's made out of steel, not aluminium.
Hans
Hans K, Cuenca, Spain
« Reply #10 on: August 14, 2018, 11:36:59 »
Yes steel.  I ended up finding another parts pump I had forgotten about.  I sort of stocked up when I decided to rebuild my pump.  PM me your address and I will send the part to you. I will never use it.
Kevkeller
  • USA, HI, Honolulu
« Reply #11 on: August 14, 2018, 12:17:55 »
Thank you Hans.
1970 280 SL
Dash808
  • USA, HI, Kaneohe
« Reply #12 on: August 14, 2018, 19:10:41 »
I've been in Mililani for quite a few years but making the move to the Kailua side of Kaneohe in Sept.  Giving the Pagoda a nice view finally  ;)
We might have to meet up for a cruise one day  8)
Chan Johnson
'67 250sl
Napoli Italian Euro
Bang Bang Booogie!
« Reply #13 on: August 15, 2018, 12:26:01 »
Authentic Classics carries the ring. There are 2 versions. The replacement thermostats require a modified ring in order to fit properly. Judging your photo you have an original type WRD thermostat. Link below:
https://www.authenticclassics.com/Seal-Ring-250SL-280SL-Injection-Pump-Thermostat-p/auth-006075.htm
Kevkeller
  • USA, HI, Honolulu
« Reply #14 on: August 16, 2018, 03:16:21 »
Thanks for the link.
1970 280 SL
