Author Topic: oil pump  (Read 1728 times)
steves sl
  • USA, WI, CEDARBURG
oil pump
« on: August 13, 2018, 20:30:38 »
I am getting ready to send my block to the machine shop. The oil pan is off....removed the two bolts on the oil pump (1 at the block and the other at the extended nut on the main cap). I just want to be sure that I know to remove the oil pump..just in case the shop asks me. What else do I have to do?
S. Schlaefer
steves sl
Re: oil pump
« Reply #1 on: August 18, 2018, 16:44:22 »
Help! Are there any other fasteners or do I have to tap on the oil pump shaft with the drive tang from above?
S. Schlaefer
Kevkeller
  • USA, HI, Honolulu
Re: oil pump
« Reply #2 on: August 18, 2018, 17:53:39 »
That’s it.  Just pull it out.  Not too hard.
1970 280 SL
Re: oil pump
« Reply #3 on: August 18, 2018, 23:33:35 »
Twist while pulling and it will come out easily.
