Author Topic: Fuel Lines, Cad Plating  (Read 2689 times)
erickmarciano
  • Canada, Quebec, montreal
« on: January 18, 2005, 20:11:10 »
sent some fuel lines for cad plate , is it ok if I do not block the ends of the lines?sent the parts to a aerospace company with a friend who is a mechanic on planes . It would be way more expensive to block them .....don't ask , they would need special instruction sheets from the forman since they only work on plane parts
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
SL113fan
Re: Fuel Lines, Cad Plating
« Reply #1 on: January 19, 2005, 06:52:46 »
 I had a similar concern when I dropped off a valve cover for Cad plating two days ago (non-MB car).  It's difficult for the platers to block off areas that you don't want coated; in my case I just needed the outside of the valve cover done.
Is there any harm in having the inside of a valve cover cad plated, or in Erick's case the inside of a fuel line?
Thx.
