Not to refer to what Shvegel wrote, although it supports it, but just as a caution, although you probably know this already: it is not this spring, really, that provides tension to the chain. That is why it is so important to prime the tensioner and pump it initially by hand (or rather by a large screwdriver) before you finish the assembly.
The spring, I think, is more like a return spring to keep sprocket on/in the chain, allowing the pumping action of sprocket+lever to take place all the time the chain is moving. That is at least how I understand it.
Just read about it a lot when did my timing last winter (shaft, chain, sprocket, rockers, tappets), fellow Members explained it to me and I followed the advise.
