Author Topic: Removing the brass bushings from the right axel housing shaft eyes  (Read 1954 times)
CJHenderson
  • USA, AR, Benton
I'm down to replacing the brass bushings from the right axel housing shaft eyelets. My problem being the housing shape that makes it easy to knock them out of alignment. Should I just use a dermal tool to cut a groove in them to weaken them or to heat the eyes?
1950 MG-TD
Re: Removing the brass bushings from the right axel housing shaft eyes
« Reply #1 on: August 24, 2018, 19:47:11 »
I use a hack saw to cut through the bushing and then knock them out after that.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: September 16, 2018, 23:58:07 »
Thanks Benz Dr. used you suggestion, worked great. But since I have no press I had to pounder on how to install the new one, then when looking at the bottom of my beer it cam to me. This is my version of a press.  8)
1950 MG-TD
