The 70-71 US spec trunk mounted evaporative emissions tank is no longer available and mine had the small lines broken off and kinked right at the bottom of the tank. I had a spare to work with so I decided to try a fix. I turned a piece of brass to match the contours of the original heat sealing on the stubs and then I brazed it to an old pair of pliers. I drilled out the old hose and then I heated the pliers up until they melted a sample of hose evenly a little squeeze and voilla!
