Author Topic: Testing a Solenoid  (Read 2707 times)
twinoakchef
Testing a Solenoid
« on: August 31, 2018, 15:11:12 »
How is a stater solenoid tested? I want to find out if the solenoid is good or on the edge of failing.
68 280 SE coupe
70 280 SL
71 280 SEL - RIP 5.28.2010
08 R320 CDI
ejboyd5
  • Southold, NY
Re: Testing a Solenoid
« Reply #1 on: September 01, 2018, 13:04:48 »
twinoakchef
« Reply #2 on: September 01, 2018, 23:30:58 »
No it has not.
68 280 SE coupe
70 280 SL
08 R320 CDI
« Reply #3 on: September 04, 2018, 23:08:22 »
Best way would be to do voltage drop test across the solenoid.  Connect a voltmeter between the two large terminals of the starter and have someone hit the key.  Anything more than 1/2 a volt with the starter turning the engine and the contacts are bad.  This is a good test you can use to find bad grounds etc because it checks how good the contacts are under a load.  It works well for things like battery cables etc.  You can measure voltage between the negative battery terminal and the engine block during cranking or between the positive terminal of the battery and the post on the starter to check the integrity of the positive cable.
