Author Topic: AM Pea Soup  (Read 4987 times)
AM Pea Soup
« on: September 09, 2018, 15:34:02 »
Took an early morning drive in the fog. Took advantage of the factory fog lights. Does anyone else use their fogs as DRL’s? I usually use them on winding roads.
mbzse
Re: AM Pea Soup
« Reply #1 on: September 09, 2018, 15:38:25 »
Quote from: Tyler S.
.../...the factory fog lights. Does anyone else use their fogs as DRL’s? .../...
I do, very often. Driving lights at all time are mandatory here, I'd rather use the fog lights over the dipped main lights.
« Last Edit: September 09, 2018, 16:31:21 by mbzse »
/Hans S
Re: AM Pea Soup
« Reply #2 on: September 09, 2018, 16:05:12 »
Me too. Always, as lights during the day are compulsory here as well. Using headlights is more burden for alternator and it also makes all the small and more difficult to replace bulbs in the dash burn faster.
It just required some re-wiring.
pj
  • Canada, ON, London, Ontario
  • 1965 230SL
    • my home page
Re: AM Pea Soup
« Reply #3 on: September 09, 2018, 18:14:44 »
Is the re-wiring that is required described somewhere?
Peter J
1965 230SL #09474 named Dagny
2018 B250 4matic named Rigel
Re: AM Pea Soup
« Reply #4 on: September 09, 2018, 18:50:54 »
On my 250, an additional pull switch can be wired up to terminal “N” on the back of the headlight switch, or it can be wired to the small fusebox next to the brake booster. This will enable them to be turned on independently of the headlight switch pull function in which the parking/tail lamps are also enabled.
YRMV as there are variations on how the fog lamps are tied in at the factory.
Re: AM Pea Soup
« Reply #5 on: September 09, 2018, 18:51:06 »
I wrote this post some time ago:
https://www.sl113.org/forums/index.php?topic=26344.msg188587#msg188587
In essence it is about powering the fog lights independently form headlights.
BlackJack
Re: AM Pea Soup
« Reply #6 on: September 28, 2018, 19:24:18 »
After importing my US 280 SL to Europe I had the lights rewired in such a way that the first position of the light switch clock-wise turn the fog lights on which I use as day time driving lights. They also function as turn signals. I have not changed my headlights to Euro version.
