Author Topic: top cover latch problem  (Read 1690 times)
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« on: September 22, 2018, 21:48:02 »
Hello All,
After many attempts to unlatch the top compartment cover, I was successful. When I finally got it open I discovered that the spring "C" clip that tensions the nut on the end of the handle shaft had completely fallen out.
Chain of failure: the retaining nut loosens up, the C clip drops out, then the lever arm backs off of the flats on the shaft.
I modified a sprinkler valve shut-off tool by adding a hook to it. It worked well on the drivers side, but on the other side I had to hook and jerk the push-pull cable instead of tripping the actual latch (no access).
The page: https://www.sl113.org/forums/index.php?topic=5681.msg35096#msg35096 was helpful but not definitive. I would like to add my graphic to this old post but do not know how to do that.  - - Peter - - HELP!
Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
mbzse
Re: top cover latch problem
« Reply #1 on: September 22, 2018, 22:06:38 »
Quote from: lurtch
.../... to unlatch the top compartment cover.../...
This procedure has been touched upon in this Forum...  se for instance:
https://www.sl113.org/forums/index.php?topic=23360.msg167197#msg167197
/Hans S
