Author Topic: Dutch 230 SL Pagode 1965 restoration project  (Read 121560 times)
EeVeeWee
Re: Dutch 230 SL Pagode 1965 restoration project
« Reply #100 on: February 20, 2019, 19:08:47 »
The sheet work will be made as smooth as possible, so a minimum of filler will be necessary.
« Last Edit: April 28, 2019, 09:53:11 by EeVeeWee »
Again something else.
EeVeeWee
« Reply #101 on: February 21, 2019, 21:04:19 »
A lot of the small parts have become like new again.
« Last Edit: April 28, 2019, 09:56:08 by EeVeeWee »
BlackJack
« Reply #102 on: February 22, 2019, 11:56:55 »
How did you get them so clean?
« Reply #103 on: February 22, 2019, 21:26:09 »
Well,
I think Eric's parts are already non-yellow cad (or zinc) plated.
EeVeeWee
« Reply #104 on: February 26, 2019, 20:37:11 »
The brake adjusting plates had to be fixed at the pins again.
I made a tool to press the spring together with the plate in position.
After welding I grinded off the excess material.
And finally put this side in the paint.
« Last Edit: April 27, 2019, 17:21:37 by EeVeeWee »
« Reply #105 on: February 26, 2019, 22:09:28 »
Cool you made it!
EeVeeWee
« Reply #106 on: February 27, 2019, 18:36:44 »
I've been working on assembly of the front brakes.
The RH back side of the car is already smooth, the LH side is in progress but nearly ready.
« Last Edit: April 27, 2019, 17:19:00 by EeVeeWee »
« Reply #107 on: February 28, 2019, 20:04:49 »
No yellow plating of calipers?
EeVeeWee
« Reply #108 on: February 28, 2019, 20:45:49 »
Not everything indeed.  ;D
EeVeeWee
« Reply #109 on: March 02, 2019, 14:42:27 »
All dents from the body have been removed now.
But like the trunk lid, the bonnet is also pretty dented.
« Last Edit: April 27, 2019, 17:17:03 by EeVeeWee »
andyburns
« Reply #110 on: March 02, 2019, 20:49:17 »
Is that from media blasting.  That operator should have been sacked.
1963 230sl
1967 250s w108
1969 BMW 2002
2007 Mitsubishi i car
EeVeeWee
« Reply #111 on: March 02, 2019, 21:18:29 »
I don't know what the cause was, it was done before I bought it and filled with bondo.  :-\
johnk
  • USA, OH, Avon
« Reply #112 on: March 03, 2019, 01:32:08 »
i woder if an experienced metal worker cold shrink the alumunum?
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
EeVeeWee
« Reply #113 on: March 03, 2019, 08:32:42 »
I found one who is specialised in aluminum, so in a few weeks we will know.  :)
EeVeeWee
« Reply #114 on: March 03, 2019, 20:49:54 »
The heat exchanger is also like new again.
« Last Edit: April 27, 2019, 17:15:54 by EeVeeWee »
EeVeeWee
« Reply #115 on: March 10, 2019, 18:44:29 »
I am amazed about how complex the lock and window mechanism is, inside the doors!
« Last Edit: April 27, 2019, 17:13:37 by EeVeeWee »
EeVeeWee
« Reply #116 on: March 12, 2019, 19:46:23 »
Cleaning parts gives a lot of satisfaction.  :D
« Last Edit: April 27, 2019, 17:12:07 by EeVeeWee »
« Reply #117 on: March 12, 2019, 20:03:40 »
I feel exactly the same way about it!
EeVeeWee
« Reply #118 on: March 14, 2019, 19:58:53 »
I bought a set NOS tools for the Pagode.
Of course with the intention never to use it.  ;D
« Last Edit: April 27, 2019, 17:11:04 by EeVeeWee »
« Reply #119 on: March 14, 2019, 20:30:54 »
Well, I do not want to ruin the party or appear not polite, but... you might want to check Technical Manual on Tool Set.
EeVeeWee
« Reply #120 on: March 15, 2019, 09:27:59 »
You can't ruin my party, because I like the tools and don't buy stuff to make someone else happy.  ;)
« Reply #121 on: March 15, 2019, 10:14:12 »
ok, a bit of relief then...
The tools are indeed in a very nice condition!
EeVeeWee
« Reply #122 on: March 17, 2019, 17:23:55 »
I cleaned a lot of parts of the dashboard which were covered with MB-Tex.
Now I will try to find new MB-Tex (or similar) with the color code 2102 (white gray).
« Last Edit: April 27, 2019, 17:09:39 by EeVeeWee »
« Reply #123 on: March 17, 2019, 21:15:29 »
Hi Eric,
Maybe you should have a look at https://cabrio.de/en/interiors-khm/genuine-leather-interiors
They sell Leather (dashboard coverings) in all official w113 colors.
EeVeeWee
« Reply #124 on: March 18, 2019, 07:53:54 »
Hi Eric,
OK Thank you!
