Become a
Full Member
Emergency Contact List
Electrical and Instruments
123 ignition loose hold down clips
Topic: 123 ignition loose hold down clips (Read 2291 times)
dakman29
Full Member
Senior
USA, WA, Spokane
September 29, 2018, 17:07:45 »
I have a 123 electronic ignition in my car (68 280 sl). I find that the hold down clips do not fasten tightly to the cap. Just wanted to know if anyone else experienced this issue and is there a recommended fix. For the time being I've just put some putty in the area on the cap where the clip fastens. Not a very elegant fix, however. Any suggestions? Thanks.
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Re: 123 ignition loose hold down clips
September 29, 2018, 17:34:32 »
Yes, similar issue, I wrote about it some time ago - the spring clips went lose. I bent them back so that they fit. You can do it with your fingers without taking the cap out, which is not good...they are too soft.
Last Edit: September 29, 2018, 20:32:03 by Pawel66
Associate Member
Platinum
USA, CA, Encinitas
Reply #2 on:
September 29, 2018, 18:55:43 »
Yes as Pawel writes. Add/bend more of an arch into them.
