Author Topic: Do you know where this plugs into?  (Read 8651 times)
Jim Donati
Re: Do you know where this plugs into?
« Reply #25 on: October 08, 2018, 16:48:15 »
Peter: That is very interesting that your '70 has the same unconnected plug as mine. I will be interested in knowing what you learn.
Jim
« Reply #26 on: October 08, 2018, 17:26:01 »
Since yours is a 1970 model, given the location of the connector I'm going to go with either a clutch pedal/starter interlock switch or a door buzzer.  Door buzzer seems more likely, simply because the then new requirement for an audible "key in the ignition" warning was annoying as all get out and a lot of us used to disable the */!@# thing back in the day.
Jim Donati
« Reply #27 on: October 08, 2018, 17:28:37 »
 ;D  very reasonable suggestion.  You could be correct :)
« Reply #28 on: October 08, 2018, 20:30:28 »
Yes, latest Pagodas (maybe just USA) had a round warning buzzer.  Green and red colors possibly?
