Become a
Full Member
Emergency Contact List
Body, interior, paint, chrome, and cosmetic items
Removal of hood tension spring
Topic: Removal of hood tension spring (Read 1823 times)
johnk
Full Member
Platinum
USA, OH, Avon
October 03, 2018, 03:36:23 »
What I founf from searching the forum and the tech manual is that the spring can be removed after taking the hood off the car and removing the plastic plates that hold the spring it in place. Mine doesn't seem to want to go anywhere after doing the above. The end that takes a 90 degree angle to goes into the channel doesn't seem to want to get pulled out. Any advicce as how to proceed from here is greatky appreciated. Do I just pull harder and hope nothing bad happens?
John
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
cfm65@me.com
Associate Member
Gold
Cape Town, South Africa
Re: Removal of hood tension spring
October 03, 2018, 05:51:35 »
Hi John,
Yep, just give it a tug and the end should slip out of the elongated slot. Ensure that there is no tention on the spring and it will come out.
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
WRe
Full Member
Platinum
Germany, Hessen, Seeheim-Jugenheim
Reply #2 on:
October 03, 2018, 07:41:47 »
See here:
https://www.sl113.org/forums/index.php?topic=26409.msg189004#msg189004
...WRe
johnk
Full Member
Platinum
USA, OH, Avon
Reply #3 on:
October 03, 2018, 11:42:44 »
thanks gents. I will just pull harder.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
