Author Topic: heavy clutch pedal  (Read 1783 times)
moose2111uk
heavy clutch pedal
« on: October 10, 2018, 19:05:34 »
Hello just been fitting a 6 speed conversion to a 250sl pagoda has a 280 engine fitted and using a  280 clutch  pressure plate i seem to have a very heavy pedal how do you adjust the over center spring on the pedal to make it lighter ? or is there another way to make the pedal lighter ? thanks in advance martin
moose2111uk
Re: heavy clutch pedal
« Reply #1 on: October 13, 2018, 08:08:38 »
Found the problem the 250 has a big capacity clutch master cylinder the 280 is much smaller so that makes the clutch a lot lighter
