Author Topic: lateral support rod  (Read 1397 times)
AB
  • USA, GA, Atlanta
lateral support rod
« on: October 15, 2018, 02:31:50 »
I have replace all rubber and seals one the rear end and I am having trouble with alignment.  I have no trouble with the measurements, it's turning the lateral support rod to make the adjustments.
The lateral support rod on later model cars is mounted in a box structure that seems to prevent access to the cast nut on the rod.  The cast nut on the rod is inside the body structure with a rubber boot in the way.  Is there a special tool to fit up in the box or do I lock two nuts together on the far end and adjust from there?  I feel like I'm missing something obvious.  Found nothing in the manual or searches.
Thanks for your comments.
1970 280SL, Anthracite Grey Metallic, Light Grey Metallic Top
Shed fined not run in ten years.  Acquired in Oct 2015
