Please check out joining the
Emergency Contact List
for help during your travels!
Body, interior, paint, chrome, and cosmetic items
spare part list
Topic: spare part list (Read 1741 times)
Facelvega
Associate Member
Junior Level
Germany
spare part list
October 21, 2018, 14:35:52 »
Is there a spare parts list available in the forum as PDF or similar?
I need to see the body construction underneath the dashboard because sometime water is coming in under the dashboard.
thanks
Pagoda SL Board
Platinum
USA, CA, San Marcos
Re: spare part list
October 21, 2018, 14:48:27 »
Check the two drain hoses from the scuttle box (air vent inlet) you can see these just looking under the dash just above each side of the transmission tunnel. The allow water to drain from the air inlet through the firewall. The hoses will age and crack (or may also be partially plugged).
You can also use the search function. Use the one in the row of options - starting with "Home" that will search the entire forum.
Here is one thread -
https://www.sl113.org/forums/index.php?topic=22082.msg157665#msg157665
There were several others that may help, I used "water leak" with the quotation marks and got a single page of items, easy to read through.
Good luck
spare part list
