Author Topic: need help identifying "B" pillar panel holes for mounting screws.  (Read 1781 times)
merrill
hello
my upholster recovered my "B" pillar panels but covered over one of the holes that secure the panel to the car.
I have located the 3 screws that run up the door jamb, but I cannot locate the 4th screw which i vaguely recall are located on under the rear seat box.
if anyone has a photo showing the 4th scerw location I would appreciate it
Matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
Re: need help identifying "B" pillar panel holes for mounting screws.
« Reply #1 on: October 22, 2018, 15:15:59 »
i found this photo online,  this looks to be in the general location from my memory.
I will take a look when i get home
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
mbzse
« Reply #2 on: October 22, 2018, 15:26:16 »
Quote from: merrill
.../..."B" pillar panels but covered over one of the holes that secure the panel to the car.
I have located the 3 screws that run up the door jamb, but I cannot locate the 4th screw which i vaguely recall are located on under the rear seat box.../...
Not sure I follow you; but, perhaps this is what you seek(?)  4th hole by arrow
/Hans S
merrill
« Reply #3 on: October 22, 2018, 17:42:33 »
Hans
yes!  perfect
I went home at lunch and located the hole.  It is at the very edge in that corner.
would have missed it without the photo.
thank you for your help
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
